Martin: I created two empty repositories:
- https://github.com/ros-drivers/phidgets_drivers
- https://github.com/ros-drivers-gbp/phidgets_drivers-release
You should be able to push your existing source and release repositories to them. Let me know if you find any permission problems.
Moving a released, maintained repository is a little tricky. I usually forget something. As a start, don’t forget to update:
- all the relevant
distribution.yaml
files inrosdistro
tracks.yaml
in your release repository’smaster
branch - source and bug report links in the various
package.xml
files
Maybe someone here will remember something I’ve forgotten.
