Hi !
I’m writing a package that needs to read a configuration file .
I use install(FILES xxx.yaml DESTINATION share/${PROJECT_NAME}) to copy the configuration file to the path : /shr/package-name
But i have no good way to get the right path where the file stores and then read it
i’m using the absolute path to read the file now but i want to make it relative so the package can be used in different environment .
Thanks for the question, but we ask that you post it on answers.ros.org with the ros2 tag instead. You can link to it from here once you do so.
