Thanks @mamerlan, meeting is happening today. I know it’s a bit late in Spain but provided I don’t mess up out of being tired, recordings should be out soon after the meeting. We’ll keep minutes nevertheless
As for alignment with Embedded WG, I’m sure you know I’m quite tuned to micro-ROS. I look forward to cooperate. Here’re some early thoughts for alignment between the HAWG and the EWG:
- it’d be interesting to run micro-ROS Client in either the R5s or into a soft-core (e.g. in a MicroBlaze)
- it’d be interesting to offload the agent into Programmable Logic (the FPGA)
- which obviously leads to consider pushing part of FastDDS also to the PL
We’ve got a few more ideas involving other architectures for mixed-criticality and link layers that allow for real-time distributed communications (e.g. TSN).
