Sorry about that @JonM.
meta-ros provides exactly this @Joe_Dinius. Check out the branches to meet whatever Yocto version you’re using.
I had to answer this recently and made a gist for it, here it is: Is it possible to install ROS2 in petalinux? - Zynq UltraScale+ MPSoC · GitHub
For those that would rather avoid building their own rootfs, acceleration_firmware_kv260 addresses exactly ths problem and provides a ready to use rootfs with various kernels (including a fully preemptible one) and ROS 2 Foxy. Check out KRS alpha release for more details (note this only supports Kria SOMs, for other SOMs, one would need to build the corresponding acceleration_firmware_* package).
What do you mean? A container having what exactly? And for what purpose? If it’s just the rootfs, that’s pretty easy to do from acceleration_firmware_kv260.
