tldr: Increase your group’s visibility on the local ROS scene by adding it to the ros_map
It is no secret that I like aggregating data. A few years ago, I started a crowd-sourced map for the purpose of helping people find other ROS users in their area. This is your occasional reminder to add your group to the map, which could help you find other people/companies/schools using ROS in your area. You might find someone to hire, or someone to hire you.
But the map is only as good as its data. You can contribute via creating a pull request on the data itself. I even added a command line script so you don’t even have to manually look up your lat/long.
