If you’re going to consider GeoJSON as an option for interchange, just know that you can completely ignore long,lat in the spec and just pretend it’s x,y. Been doing this for many projects well over a decade and can say it works fine, assuming you’re utilizing tools that don’t just assume a CRS like WGS84. There’s hundreds of geodata formats so pick what makes sense, but resist making your own. GeoJSON is great because of the countless tools and libraries already available for it.
For QGIS all you need to do is set a custom CRS to a planar Cartesian system (just set everything to zeroes). Everything else just works including the extensive suite of raster and vector tools (see my ROSCon talk for examples of QGIS showing an indoor facility with robots in real-time).
Orthorectified imagery or PDF floorplans are basically the same thing when you think about it. Set control points from known fiducials and begin drawing. Thinking all the way back to school, we’d just rasterize the PDF and run it through QGIS akin to how one would an unrectified satellite/aerial image.Though often a SLAM map is used as the “ground reference” and you draw on your vectors relative to it.
Yes, there is a lot to be said about a limited UI, which is probably why I keep end up making them. Depends what your goals, timelines, etc. are. QGIS may fill a gap shorter or longer term, and it’s always a phenomenal analysis and data processing tool.
Feel free to email me with any questions you’ve got with getting started.
