One of these questions got [deleted], the other [closed as duplicate], and in the meantime a very valuable answer disappeared. Fortunately, I had read the message before, but possibly someone other would also find it useful.
I think there might be a bug in the askbot UI that only renders each title once on your profile since you asked two questions with the same title. You only see 2 of the three on your profile.
Please be careful not to ask duplicate questions as this too 2 or 3 people to both answer your question as well as to triage them as duplicates and remove or close them. https://wiki.ros.org/Support
imagine that you ask a question, then you decide to change the topic (I remember hitting the “edit” button), then I hit “edit” again but to change the matter, then it turns out that I “posted” 3 questions, so I presume some glitch in the system, so I report it, and get an answer along the following line…
“be careful and do not ask the same thing multiple times because”…
