Currently a node lives in a executor, and callbacks from timers and subscriptions are executed by that executor, taking callbackgroups into account.
However, sometimes I have a trigger from somewhere else, not related to ROS, that I want to handle in that same context, This to prevent having to fiddle with mutexes etc.
Basically something like this:
rclcpp::Node::execute(CallbackT && callback, rclcpp::callback_group::CallbackGroup::SharedPtr group = nullptr);
I then expect the callback to be executed as soon as possible in the same way as a subscription or timer callback.
Now I do it by creating a one-off timer with a duration of 0, but it’s not the nicest thing in the word. Would it be useful to have something like that in ros2?
Yeah it also works indeed, it’s just that to make a one-off timer you need to store the timerhandle and make it accessible to the callback in order to make it one off.
Just for reference, i now use the following utility:
I solved a similar issue creating a custom objects that inherits from rclcpp::Waitable.
This is registered similarly to subscription callbacks and it can be triggered externally. In my case it’s triggered whenever data is added to a buffer.
