One thing that has been increasingly annoying is that there is insanely good academic research in neural nets but 99% of the time the code is written in the most haphazard, undeployable fashion possible. Typically you have to clone some git repo, download some zip file of weights from a Dropbox, deal with grad students having used Windows case-insensitive filenames, put JPEGs in some directory with some file naming format, and run silly shell scripts like “run_inference.sh” rather than a nicely-built, deployable class that you can pip install and import into another project.
Of course, as a PhD myself, I completely understand where the academics are coming from. Most of them are good at math, not software engineering.
For production use though, one thing I’ve been thinking about is having a more generalizable neural net packaging framework where to switch from one neural net to the other, you only have to point your execution framework at a different package, and not have to read any documentation to switch between one net and another.
I’ve created this prototype:
which implements semantic segmentation agnostic of the network and agnostic to the neural net framework used. I’ve included a couple examples that are TensorFlow-based and one example that is PyTorch-based, and the only thing you have to do to switch between them is to change a single ROS parameter.
I’d love feedback on this general concept or how we can propagate such a standard through the community. I’d also love for it to be generalized beyond semantic segmentation. Perhaps a hierarchy of classes, e.g. a NeuralNet class, a SemanticSegmentation class, ObjectDetection class, SpeechRecognition that inherit from the parent class, and so forth, where to implement a deployable, say, ObjectDetection class, all you have to do as the researcher is override the required methods, and you can do so using whatever code you wish. So for example, MaskRCNN overrides a couple of methods, inherits from InstanceSegmentation, which inherits from NeuralNet.
