That depends what you exactly mean by “read only issues”:
  • you can disable the tracker on a repository, then make it clear that issues should be reported on the Gitlab tracker
  • as to mirroring issues: that is difficult, as you cannot faithfully mirror things like authorship and other properties between GH and Gitlab
The first I’ve often seen done, the second never really successfully.
Note that you can’t disable PRs, but you can clearly place a “warning” somewhere that PRs opened against that repository will be ignored.
Example: wireshark/wireshark.
