Are you a ROS user? Are you attending IROS 2022? Do you desperately desire not to awkwardly approach a table to sit at with total strangers you may well find out you have absolutely nothing in common with (or am I just projecting)?
If you answered yes to 2 (or 3) of those questions, join us for a ROS users lunch meetup during the lunch period on October 25 (Tuesday).
Follow this thread for more information. See latest comments for location and a map pin!
Lets meet tomorrow during the lunch break outside. Directly away from the building across the water there’s an open field with a ledge on the left-hand side.
To get there, go across the dock, continue back, past the vista platform, until you’re at the water’s edge where it meets grass. I’ll be on the rock wall. You should be able to also see me on the other side of the water when you first exit the building, so it should be obvious alternative routes to get there.
See the image for a pin! I look forward to seeing you all!
