Thanks for the response @zmk5. While my main goal is actually to run Qt apps, out of curiosity I tried ignoring rviz and ros-visualization as you described, and I still have a number of failing packages:
  1 package failed: sip
  4 packages aborted: ament_cmake_core ament_flake8 ament_pyflakes test_osrf_testing_tools_cpp
Trying to avoid the sunk cost fallacy, I bit the bullet and set up a desktop computer running Ubuntu 20.04 alongside my mac.
In this new environment, I was able to get ROS2 up and running in a couple hours. (Compare this with literally more than 40 hours trying and failing to get things running on macOS.)
  • Pro: I can finally start working.
  • Cons: I cannot use my carefully-configured terminal environment, editors, OS keyboard shortcuts that I’ve built up over the last 10 years. I also now have two computers, monitors, keyboards, and mice on my tiny desk which is super annoying.
I appreciate that others have had more luck than me. I have ~15 years of software dev experience but have never used ROS before, and that might be working against me. I also appreciate that Ubuntu may have been easier because it’s a “throwaway” environment and I was willing to install dependencies globally, whereas I use my mac for many projects and cannot afford to pollute the global environment.
For maintainers of ROS2: I would highly recommend you put some big warnings on the pages that claim support for macOS. I feel somewhat gaslit and misled into believing that it’s a tier-1 platform, and that my difficulties have been my fault. Please recommend that people use Ubuntu until the Mac developer experience has been improved.
For mac users hoping to run ROS2 natively: Expect to spend a lot of extra time setting up, and potentially not succeeding. A second physical machine or VM might be preferable depending on your needs. The official Docker images are super easy to set up if you don’t need the GUI.
I sincerely wish I was able to contribute more to this effort. The most I was able to do was to answer my own question here. However this has become a huge time sink for me and I can no longer justify the effort.
Good luck all!
