Issues about Migration Guide
Hi everyone,
I tested the example from the Migration Guide in my PC(win 10 x64, binary packages installation) and found some issues.
cmake_minimum_required(VERSION 2.8.3) → cmake_minimum_required(VERSION 3.5)
auto node = rclcpp::node::Node::make_shared(“talker”); → auto node = rclcpp::Node::make_shared(“talker”);
rclcpp::rate::Rate loop_rate(10); → rclcpp::Rate loop_rate(10);
BTW, I’m not sure that rclcpp::Rate spins while it sleeps. It hasn’t in times gone by. Generally, you will break things in ROS2 if you sleep instead of spin; your buffers will overflow, etc. We usually use the timeouts on the spin methods instead.
The migration guide is a wiki page. Please feel free to edit it and improve it where you see fit. It would be good to post a link to the diff here afterwards to make others aware of your change. Thanks.
