I agree changing other ROS features to use keyed topics is a much larger undertaking. The only thing we are specifically looking for is the ability to create a msg file which will cause them to be generated at this point. RTI’s implementation looks for the (@)key at the end of the line, so realistically just passing along comments from a msg file to the IDL would make this work. For example, our msg file is below:
string<=512 key #//(@)key
string<=512 value
We made an update to basically pass this along so the IDL file now includes the following:
struct Parameter_
string<512> key_; (@)key
string<512> value_;
}; // struct Parameter_
This obviously doesn’t solve the problems with discovery that @dirk-thomas mentioned, but it allows the global parameter setup @wjwwood mentioned, which is how we are using it.
