Hi @mitsudome-r,
so, if we go for option (2) or option (3) we have something like that right ?
So, because we are using the same library we don’t need a big structure of ROS msg (it would duplicate the work), and just use lanelet to manage errors in read/write a msg.
About the errors. should we have a way to send a feedback to the server in case the map delivered (XML or BIN) is good or bad ?
Also … should the msg be a requrest/response or pub/sub ? in our case, for parking garage maps, request response is good enough (you ask for the map of a given area when you are getting closer to it). Is it similar to what you are doing ?
