So, because we are using the same library we don’t need a big structure of ROS msg (it would duplicate the work), and just use lanelet to manage errors in read/write a msg.
That was my idea.
About the errors . should we have a way to send a feedback to the server in case the map delivered (XML or BIN) is good or bad ?
I am not sure if we should have this feedback. If we are going to have one, then the server should do something when they get the error message, but I don’t know if there is anything server can do about it. Maybe sending the topic again if it is pub/sub? Also, what do you mean by good or bad? Are you talking about corruption of data?
Also … should the msg be a requrest/response or pub/sub ? in our case, for parking garage maps, request response is good enough (you ask for the map of a given area when you are getting closer to it). Is it similar to what you are doing?
Our work on replacing current Aisan vector map implementation is done by pub/sub. This is just because current implementation is done that way. We should probably think about it again once we have all requirements listed up.
