gbiggs
4
Please consider in your options:
- Use of a map server with services to provide a subset of the map based on certain criteria (map in a specific area, lanes along a route, etc.), as well as a service that can provide the whole map.
- Whether you can send structured map data rather than wrapping an XML or binary chunk in a ROS message, because this would give more flexibility for other nodes to use the data even without the lanelets2 library, and would ease debugging for those who wish to debug at the topic level. This may require modifying the lanelets2 library but you should give this consideration.
- Whether using structured map data in ROS messages with that structure oriented towards use rather than source format would give more flexibility to support different map formats in the future. In other words, make your ideal map message(s) rather than lanelet2 messages.
Please also state your assumptions, requirements, and detailed use cases that will drive the decision on what sort of messages to create.
