ROS Developers LIVE-Class #65: [Robot Exploration] How Can a Robot Create a Map Autonomously
DATE & TIME
Sep 17, 2019 @ 6pm - 7pm CEST
OVERVIEW
In class #65, we will learn how to apply Frontier Exploration package to make an exploration of an unknown environment.
Why Exploration?
Most of the time you have to put a robot into an unknown environment to work, not always you’ll have a map with obstacles inside it. Sometimes you can have an environment that is changing continuously.
In both cases, exploration is a good option to navigate and map your environment at the same time and one of the most common packages of exploration is Frontier Exploration.
In this Live Class, let’s learn how it works and what it needs to work properly. GO AHEAD!
PREVIOUS KNOWLEDGE REQUIREMENTS
→Basics of ROS
→Basics Navigation in ROS
HOW TO JOIN THE CLASS
  • FREE event open for everyone, the only thing you may need to do is “set reminder” on our YouTube channel.
  • We will share the full ROSject (containing robot simulation, notebook with instructions and code) with all the attendants at the beginning of the class. Remember to be on time.
  • In Live Classes, you will practice with the instructor at the same time, with the provided free ROS material.
If you missed the class, you can find the ROSject files and full-code used in the class at the Robot Ignite Academy: https://www.robotigniteacademy.com
