I have been working with Lanelet2 over the past few weeks (including the pre-release autoware integration) and generally agree with the Pro/Con breakdown by @mitsudome-r. I have found the tagging mechanism needs more documentation/standardization for it to be used without the potential for error. One way to mitigate that may be for the AWF to define what set of tags are to be used in Autoware as well as create the TrafficRules objects for the US/UK/Japan as needed (Germany is the available default).
However, I think we should be careful about rushing too quickly into building our library from scratch. That was essentially the idea originally proposed for Autoware.ai here https://github.com/autowarefoundation/autoware/issues/1701
That received a large amount of push back from the community which wanted a standard format to be used.
Some points to consider
  1. Would an AWF implemented library still use the lanelet2 conceptual format (lanelets/areas/regulatory elements etc.)? I would prefer that over switching to an alternative without a very good reason.
  2. Would forking the Lanelet2 repo be sufficient for making the kinds of changes which might be needed?
  3. The AWF probably represents the single largest user community which would want to work with Lanelet2. Can we use that to get the lanelet2 developers directly involved?
  4. Regardless of the backend library, it would be nice if the interface used by downstream components could be largely preserved to ease porting of Autoware.ai components to Autoware.Auto. What is the practicality of doing that?
  5. Are there any functional requirements missing from lanelet2 which cannot be added without reworking the library? Pretty much all of the “cons” listed are surface level issues which represent a challenge in learning the lanelet2 API but do not represent bugs or blockers on usage of the library.
