Sorry it has taken so long for me to reply here, but I just wanted to make some short replies to help connect different parts of the discussion.
No you’re right about that. We’ve thought about it enough to start the design doc and to implement the parts we believe are necessary to support ROS 1 style sim time in rcl’s C code, but we’ve stopped short of implementing ROS 1 style sim time (using a /clock
topic) or exposing it in C++ and making an example to demonstrate how it would work.
I agree, this is a crucial feature in ROS 1 and I think we need it in the core of ROS 2 as well.
Your right, and thanks for starting to discuss this related topic there (@tfoote already referenced it too): enhanced time article to include realtime factor by BrannonKing · Pull Request #128 · ros2/design · GitHub
I think we can continue to discuss the options for /clock
(or a similarly named topic) in that pr.
There’s a lot more to comment on @BrannonKing’s original post , but I’ll get back to that in another post or on the reference pr.
I agree with you.
If you look in the implementation of time in rcl it uses a single uint64_t
to store nanoseconds for a time point and a single int64_t
to store nanoseconds for a duration. I did this after much research and talking with a few people at OSRF.
I did not, however, get the chance to write down all the justifications so that I could argue that the time message be switched from the current system of two 32-bit ints to a single 64-bit int. There are some trade-offs, but I think it’s a good path forward. Unfortunately there would be a lot of inertia to overcome when changing this, because changing the time layout would affect lots and lots of code in ROS 1 I think. This isn’t a reason in itself not to do it, but it does mean we need to be sure it is necessary and properly justify it and provide decent migration options.
This is true, but even those on machines without 64-bit instructions, the compiler will generate code to do the 64-bit math using 32-bit registers and it will almost certainly be faster and more correct than what we do. I think this is a commonly used but weak argument against using a 64-bit type for this.
Historically the time_t
was 32-bit because it was conceived before machines and languages had 64-bit type support. This is an interesting read:
Some OS’s have already expanded their underlying storage to 64-bit. Either way we have no good reason to stick with this layout for time in our messages.
But this is an argument that needs to be made formally, so I won’t dive deep into it now.
I’ll continue with @BrannonKing and @tfoote on the pr.
