If you don’t care about arm64, then you can add it to the blacklist at ros_buildfarm_config/jazzy/release-ubuntu-arm64-build.yaml at ros2 · ros2/ros_buildfarm_config · GitHub (you’ll have to do the same for each release that you want to blacklist it from).
