The triggers are directly from the public Jenkins page I linked to at http://build.ros.org/job/Mbin_uB64__slam_toolbox__ubuntu_bionic_amd64__binary/36/
I copy and pasted the body into triggers.txt and above you can see my invocations of grep, sort, and uniq to filter them down. Then I just cross referenced those source builds to the changes in the rosdistro. And then browsed through the changelogs. Nothing magic, but a bunch of manual work.
With a core change like this the trigger lists are pretty long and the grepping is necessary. Often it’s just immediately readable. For example your most recent release caused a single trigger: http://build.ros.org/job/Mbin_uB64__slam_toolbox__ubuntu_bionic_amd64__binary/48/
If this caused a regression it would be easy to figure out where it came from.
