This revision specifies an updated recipe generation procedure that uses a cache.yaml
generated locally from a given commit of ros/rosdistro.git
. It also contains revisions to the milestones, in particular, adding support for eloquent is now to be done before adding support for OE-Core warrior.
The document is here. Its change log is here. A “rich diff” of the changes made since the previous revision is here.
