As long as the package names are “known” (which I would expect to be the case in February when they do the rebuild) we should be able to support Fedora 26.
I would even think that it might be a good idea to only support Fedora 26 then since some packages are lower then our currently planned requirements in Fedora 25. A higher version should usually not be a big problem since maintainers commonly try to keep their software compatible with newer releases (the same happens all the time on e.g. Gentoo).
