Thanks Clara. I presume the docker images will now be updated, but will lag the key update by a day or two (as happened with the non snapshot releases).
Thanks for the update @claraberendsen - building fresh containers now and the key is all good. Appreciate all of your efforts.
ros:foxy-ros-base
images for arm64 and amd64 seem to be updated now. thank you.
All snapshot based images in the official docker library have now been rebuilt
Remaining issues:
- snapshots based images hosted on osrf’s dockerhub: EOL osrf hosted images need rebuild to pick up new gpg key · Issue #818 · osrf/docker_images · GitHub
- ROS Noetic images: GPG key expired for ROS Noetic images (e.g. noetic-ros-base-focal) · Issue #814 · osrf/docker_images · GitHub
All images are now available with the updated gpg key.
Happy containing
