I’m doing a ROS sensor porting to ROS2 Ardent. To verify my porting job “done”, I use rviz (I attempted to use rviz2 but looks unready) to visualize all the sensor messages passed via ros1_bridge. And I found the “tf2_msgs/TFMessage” failed to be broadcasted via ros1_bridge for the topic “tf_static”.
This happen in a very specific scenario, and I have made one workaround in my ROS2 sensor. Would like to share the story here, and learn if anybody else facing the similar issue when porting other ROS2 sensors, or any suggestions on using ros1_bridge.
The scenario follows the ros1_bridge usage Example 1b
- launch roscore
- launch ros1_bridge “ros2 run ros1_bridge dynamic_bridge”
- launch the ROS subscriber (rviz in my case), which listen to the sensor data and then the tf messages
- launch the ROS2 sensor, which publish the sensor data and broadcast the tf messages
Till here rviz tells “No tf data”. The console debug outputs
[ WARN] [1517480472.064368531]: MessageFilter [target=camera_link ]: Dropped 100.00% of messages so far. Please turn the [ros.rviz.message_notifier] rosconsole logger to DEBUG for more information.
[DEBUG] [1517460244.760264411]: MessageFilter [target=camera_link ]: Removed oldest message because buffer is full, count now 10 (frame_id=camera_depth_optical_frame, stamp=1517460244.212398)
[DEBUG] [1517460244.760436306]: MessageFilter [target=camera_link ]: Added message in frame camera_depth_optical_frame at time 1517460244.666, count now 10
Problem still observed even when I stop/re-launch the ROS subscriber, or when I reversed the above #3 and #4.
Surprisingly, I found if I stop/re-launch the ROS2 sensor here, ros1_bridge will start to pass the tf_static!
Before digging into codes, some behaviors are obvious. Firstly, ros1_bridge will pass the messages only when the topic is subscribed AND published. Secondly, the “tf_static” topic is skipped by the ros1_bridge for certain reason. Most likely, the tf_static topic had not been subscribed when ros1_bridge doing a check when the ROS2 sensor publish its first tf message.
To be specific, here’s the problematic sequence (align with the above launch sequences)
3, ROS sub: subscribe sensor data
4a, ROS2 sensor: advertise and publish sensor data
4b, ROS2 sensor: broadcast tf_static
5, ros1_bridge: create 2to1 bridges for all topics (including sensor topics and tf_static topic)
6, ros1_bridge: passing sensor data, since those topics are both subscribed and published
7, ros1_bridge: skipping tf_static, since no listener yet
8, ROS sub: received sensor data
9, ROS sub: listen to tf_static but it has been skipped by ros1_bridge
I made a workaround in my ROS2 sensor, that is to move step #4b to the bottom. Then the problem disappeared. However the workaround is not perfect, since a ROS subscriber can start listen to a tf_static topic dynamically (anytime later).
