Hi @lmayencourt, I finally had time to look at the repository and the instructions. They look great!
However I noticed that you are still targeting Bouncy repositories.
Have you tried cross-compiling Crystal repositories using that same instructions?
I’m asking because I have created a similar framework, which should allow me to cross-compile for Bouncy as well as for Crystal.
However, even if the build phase goes fine in both cases, I get a Bus error
when running any of the Crystal example executables.
