What I meant is just like what wjwwood writes: I need to source a shell script via a system call inside Qt.
Your method of sourcing the terminal and then open qt with this terminal works for sure, but do you have any experience to run the “sourcing command” directly in Qt using system call?
If not, then I guess I’ll ask this in a more generic forum like he said.
But still, thanks for your answer!
