ROS2 Security
Thank you for your sharing, @codebot could you please share me more details regarding the following points:
for example, where to find the detail to learn more technical detail :smile:
As for SROS2, now it’s merged into the ROS2 mainline, does this mean that the mainline is always enough to use the ROS2 security features from the current to the future ? or the further development will continue on SROS2 when necessary but merge the work on SROS2 into the mainline at a certain ROS2 release milestone? thank you !
