Hi
I installed ROS2 on MAC and I run talker/listener application and both worked fine, but I found this warning (although it worked fine).
Aniss-MacBook-Pro-3:~ akoubaa$ ros2 run demo_nodes_cpp listener
Failed to load entry point ‘launch’: No module named ‘rclpy._rclpy’
Failed to load entry point ‘echo’: No module named ‘rclpy._rclpy’
Here is a screenshot
Then, I tried the commands
ros2 node list
and
ros2 topic list
and here there was serious problem as shown in the following two pictures
Is there any means to fix the problem?
Thanks
Anis
ROS Course for Beginners
https://www.udemy.com/ros-essentials/?couponCode=ROSDISCOURSE1
Please ask questions on answers.ros.org, see: https://github.com/ros2/ros2/wiki/Contact#troubleshooting
Also, please do not post pictures of text.
And please do not advertise in your signature. Making a post about a class or book is fine, but please do not include it in every post. It clutters conversations of which you’re a part.
Thanks.
Thanks and sorry for confusion!
