Rosidl_adapter
Hi ROS community,
I’m facing an issue while building MoveIt on ROS [HUMBLE] with Python 3.10.12. The error is related to the rosidl_adapter module and seems to involve an attribute error with the em module. Here’s the relevant error message:
CMake Error at /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:59 (message):
execute_process(/usr/local/bin/python3.7 -m rosidl_adapter --package-name
controller_manager_msgs --arguments-file
/home/ubuntu/build/controller_manager_msgs/rosidl_adapter__arguments__controller_manager_msgs.json
–output-dir
/home/ubuntu/build/controller_manager_msgs/rosidl_adapter/controller_manager_msgs
–output-file
/home/ubuntu/build/controller_manager_msgs/rosidl_adapter/controller_manager_msgs.idls)
returned error code 1:
AttributeError processing template ‘msg.idl.em’
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 48, in evaluate_template
  _interpreter = em.Interpreter(
AttributeError: module ‘em’ has no attribute ‘Interpreter’
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
  "__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
  exec(code, run_globals)
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__main__.py", line 19, in <module>
  sys.exit(main())
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 55, in main
  pathlib.Path(relative_path), output_dir)
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 20, in convert_to_idl
  package_dir, package_name, interface_file, output_dir / 'msg')
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/msg/__init__.py", line 39, in convert_msg_to_idl
  expand_template('msg.idl.em', data, output_file, encoding='iso-8859-1')
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 23, in expand_template
  content = evaluate_template(template_name, data)
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 69, in evaluate_template
  _interpreter.shutdown()
AttributeError: ‘NoneType’ object has no attribute ‘shutdown’
Call Stack (most recent call first):
/opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:130 (rosidl_adapt_interfaces)
CMakeLists.txt:28 (rosidl_generate_interfaces)
Details:
  • ROS Distribution: [HUMBLE]
  • MoveIt Version: [MOVEIT2]
  • Python Version: 3.10.12
I have attempted some step to resolve this but the issue persists. Any guidance or suggestions on resolving this issue would be greatly appreciated.
Thank you!
Please report the issue to the github repo of rosidl_adapter (you can use index.ros.org to find the issue tracker link).
