08-30 16:28:00.651 16610-16610/? E/Zygote: MountEmulatedStorage()
08-30 16:28:00.651 16610-16610/? E/Zygote: v2
08-30 16:28:00.656 16610-16610/? E/SELinux: [DEBUG] get_category: variable seinfo: default sensitivity: NULL, cateogry: NULL
08-30 16:28:04.626 16610-16697/com.baro.barosystem.barocar E/Resources: RunTimeException
android.content.res.Resources$NotFoundException: Resource ID #0x7f02005a
at android.content.res.Resources.getValue(Resources.java:2345)
at android.content.res.Resources.startRC(Resources.java:1059)
at android.app.ActivityThread$mRunnable.run(ActivityThread.java:2517)
at java.lang.Thread.run(Thread.java:818)
08-30 16:28:08.256 16610-16819/com.baro.barosystem.barocar E/AndroidRuntime: FATAL EXCEPTION: pool-2-thread-18
Process: com.baro.barosystem.barocar, PID: 16610
java.lang.IllegalArgumentException
at com.google.common.base.Preconditions.checkArgument(Preconditions.java:76)
at org.ros.internal.message.field.ChannelBufferField.setValue(ChannelBufferField.java:55)
at org.ros.internal.message.MessageProxyInvocationHandler.invoke(MessageProxyInvocationHandler.java:46)
at java.lang.reflect.Proxy.invoke(Proxy.java:397)
at org.ros.internal.message.$Proxy2.setData(Unknown Source)
at com.baro.barosystem.barocar.RosAlive$1.loop(RosAlive.java:109)
at org.ros.concurrent.CancellableLoop.run(CancellableLoop.java:56)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
Hey, I know that’s a bit old, but I just faced the same problem and solved it.
Ros just accepts the channelBuffer if it is little endian, so when you create you eee, you should do it like this
ChannelBuffer eee= ChannelBuffers.dynamicBuffer(ByteOrder.LITTLE_ENDIAN, 4);
