Hi all,
I’m trying to create a ROS 2 Python launch file that starts multiple launch files in a sequence. I want to start the next launch file only after a specific log message is printed by the currently running launch file. (It’s necessary for starting Nav2 with one command)
Currently, i start the launch files with ExecuteProcess
, so i can use the ProcessIO
event to catch the output message that indicates readiness. My main issue with this is that ROS 2 doesn’t seem to correctly terminate all the process when the launch file was started with ExecuteProcess
Is there a cleaner way to get launch files waiting for each? Any help or suggestions are greatly appreciated!
This is how my current solution looks like:
import launch
from launch_ros.actions import Node
from launch.actions import (
ExecuteProcess,
DeclareLaunchArgument,
LogInfo,
RegisterEventHandler,
TimerAction,
from launch.substitutions import (
LaunchConfiguration,
PathJoinSubstitution,
PythonExpression,
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch_ros.substitutions import FindPackageShare
from launch.events.process import ProcessIO
from launch.event_handlers import OnProcessIO
# Create event handler that waits for an output message and then returns actions
def on_matching_output(matcher: str, result: launch.SomeActionsType):
def on_output(event: ProcessIO):
for line in event.text.decode().splitlines():
if matcher in line:
return result
return on_output
# Lanch the robot and the navigation stack
def generate_launch_description():
# Messages are from: https://navigation.ros.org/setup_guides/sensors/setup_sensors.html#launching-nav2
diff_drive_loaded_message = (
"Sucessfully loaded controller diff_drive_base_controller into state active"
toolbox_ready_message = "Registering sensor"
navigation_ready_message = "Creating bond timer"
use_rviz = LaunchConfiguration("use_rviz")
# Including launchfiles with execute process because i didn't find another way to wait for a certain messages befor starting the next launchfile
bringup = ExecuteProcess(
name="launch_bringup",
cmd=[
"ros2",
"launch",
PathJoinSubstitution(
FindPackageShare("sam_bot_nav2_gz"),
"launch",
"display.launch.py",
"use_rviz:=false",
"use_localization:=false",
# Thy to replace with LaunchConfigurationNotEquals
PythonExpression(
"'' if '",
LaunchConfiguration("gz_args"),
" else 'gz_args:=",
output="screen",
toolbox = ExecuteProcess(
name="launch_slam_toolbox",
cmd=[
"ros2",
"launch",
FindPackageShare("slam_toolbox"),
"launch",
"online_async_launch.py",
output="screen",
waiting_toolbox = RegisterEventHandler(
OnProcessIO(
target_action=bringup,
on_stdout=on_matching_output(
diff_drive_loaded_message,
LogInfo(
msg="Diff drive controller loaded. Starting SLAM Toolbox..."
toolbox,
navigation = ExecuteProcess(
name="launch_navigation",
cmd=[
"ros2",
"launch",
FindPackageShare("nav2_bringup"),
"launch",
"navigation_launch.py",
"use_sim_time:=True",
["params_file:=", LaunchConfiguration('params_file')]
output="screen",
rviz_node = Node(
condition=launch.conditions.IfCondition(use_rviz),
package="rviz2",
executable="rviz2",
name="rviz2",
output="screen",
arguments=["-d", LaunchConfiguration("rvizconfig")],
waiting_navigation = RegisterEventHandler(
OnProcessIO(
target_action=toolbox,
# diff_drive_loaded_message,
toolbox_ready_message,
LogInfo(msg="SLAM Toolbox loaded. Starting navigation..."),
# TODO Debug: Navigation fails to start if it's launched right after the slam_toolbox
TimerAction(
period=20.0,
actions=[navigation],
rviz_node,
waiting_success = RegisterEventHandler(
OnProcessIO(
target_action=navigation,
navigation_ready_message,
LogInfo(msg="Ready for navigation!"),
return launch.LaunchDescription(
DeclareLaunchArgument(
"params_file",
default_value=[FindPackageShare("sam_bot_nav2_gz"), "/config/nav2_params.yaml"],
description="Full path to the ROS2 parameters file to use for all launched nodes",
name="rvizconfig",
default_value=[
"/rviz/navigation_config.rviz",
description="Absolute path to rviz config file",
"gz_args",
default_value=" ",
description="Extra args for Gazebo (ie. '-s' for running headless)",
name="use_rviz",
default_value="True",
bringup,
waiting_toolbox,
waiting_navigation,
waiting_success,
