I am also familiar with the BufferServer. Which is cool, but the use case differs slightly and ours is more of a drop-in replacement where you don’t need to think about the launch of another shared component or executor (service calls in callbacks can be a bit tricky sometimes) too much. Still, for low volume queries from many nodes yours is probably better, while our probably has a lower latency / cost per query. But this is just a guess, so I could be wrong.
