Uploading large PCD file to tier4 maptool
Hello!
I am trying to use tier4 maptool to create vector map in ADAS format. But the online tool seems to limit the uploaded file size. I can upload a segment of the PCD file(~10mB), but not the entire map(~70mB). Anyone know how to deal with larger vector map building problem?
Thanks!
Have you tried increasing downsampling rate?
Thank you for replying! I wish to keep the details in the map, so I didn’t downsample the data. And in the future, I plan to deal with larger map (a few GB). That’s why I am looking for a long-term solution to make vector map.
I tried to increase downsampling rate to 1000, but it doesn’t work as well.
1000 might be too large.
I have succeeded uploading 125MB pcd with downsampling rate of 5, so I think the problem is not related to file size.
It may be that points are too small to be seen. You can press ctrl and ‘+’ to make points larger.
You could also try breaking your pcd into pieces rather than uploading one big file.
