@wjwwood: Thank you for your input!
I checked the code more closely and it is actually encoded in rclcpp::Time
which clock was used. This is great! But if it set to RCL_ROS_TIME
I have no information about the state of the clock which was used to create this rclcpp::Time
, right? Maybe it was simulated time, maybe something else. Should rclcpp::Time
not have a pointer to the associated rclcpp::Clock
Maybe I am missing a feature in ROS 2 time which solves this issue but I am unable to find it.
I am also unsure about the solution how would one implement the conversion from rclcpp::Time
to std::time_point
??? to_time_point(rclcpp::Time time) {
if(time.get_clock() == RCL_SYSTEM_TIME) {
return std::chrono::system_clock::time_point(time.nanoseconds()ns)
else if(time.get_clock() == RCL_STEADY_TIME) {
return std::chrono::steady_clock::time_point(time.nanoseconds()ns)
else {
//ERROR not supported.
One could use boost::variant
or extend the standard library but those are surely not optimal solutions.
