I have started in my github to complete your implementation :
with:
- JavaDoc
- Header file (but i see you push-it in your last commit why not use OSRF ?)
- QoS profile
- Testing (but I need to add on gradle)
- Java Service (need to add on JNI call)
- Java Parameter (need rcl finished by core team)
I propose to you to make a clean Merge Request of JavaDoc and Testing.
For the launch case :
Nothing was define in ROS2 design page, but by experience of ROS1 if i make a xxxxxx.laucnh file and java is special.
In your implentation you need to :
eg. java -cp install_isolated/rosidl_generator_java/share/rosidl_generator_java/java/rosidl_generator_java.jar: ....
I would like to know if is possible to generate a simple script for shortcut the launch.
eg. talker_java.sh (or without exention)
