Hi.
I copied a repository from github and when i try to build i get this error:
m@u:~/suruiha-ws$ catkin_make
Base path: /home/m/suruiha-ws
Source space: /home/m/suruiha-ws/src
Build space: /home/m/suruiha-ws/build
Devel space: /home/m/suruiha-ws/devel
Install space: /home/m/suruiha-ws/install
#### Running command: "make cmake_check_build_system" in "/home/m/suruiha-ws/build"
#### Running command: "make -j4 -l4" in "/home/m/suruiha-ws/build"
[ 20%] Built target uav_ground_control
[ 30%] Building CXX object suruiha_gazebo_plugins/CMakeFiles/iris_controller.dir/src/iris_controller.cpp.o
[ 40%] Building CXX object suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/zephyr_controller.cpp.o
[ 50%] Building CXX object suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/joint_control.cpp.o
[ 60%] Building CXX object suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/util.cpp.o
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/joint_control.cpp: In member function ‘void gazebo::JointControl::SetPosition(double, gazebo::common::Time)’:
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/joint_control.cpp:50:44: error: ‘class gazebo::physics::Joint’ has no member named ‘Position’
const double currentPos = this->joint->Position(0);
suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/build.make:86: recipe for target 'suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/joint_control.cpp.o' failed
make[2]: *** [suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/joint_control.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/iris_controller.cpp: In member function ‘virtual void gazebo::IrisController::UpdateStates()’:
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/iris_controller.cpp:221:44: error: ‘class gazebo::physics::World’ has no member named ‘SimTime’
common::Time currTime = this->world_->SimTime();
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/iris_controller.cpp:226:52: error: ‘class gazebo::physics::Model’ has no member named ‘WorldPose’
ignition::math::Pose3d pose = this->model_->WorldPose();
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/iris_controller.cpp: In member function ‘void gazebo::IrisController::CalculateRotors(double, double, double, double, gazebo::common::Time)’:
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/iris_controller.cpp:252:40: error: ‘class gazebo::physics::Model’ has no member named ‘WorldPose’
ignition::math::Pose3d pose = model_->WorldPose();
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/zephyr_controller.cpp: In member function ‘virtual void gazebo::ZephyrController::UpdateStates()’:
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/zephyr_controller.cpp:119:44: error: ‘class gazebo::physics::World’ has no member named ‘SimTime’
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/zephyr_controller.cpp:124:52: error: ‘class gazebo::physics::Model’ has no member named ‘WorldPose’
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/zephyr_controller.cpp: In member function ‘void gazebo::ZephyrController::CalculateJoints(double, double, double, gazebo::common::Time)’:
/home/m/suruiha-ws/src/suruiha_gazebo_plugins/src/zephyr_controller.cpp:152:47: error: ‘class gazebo::physics::Model’ has no member named ‘WorldPose’
suruiha_gazebo_plugins/CMakeFiles/iris_controller.dir/build.make:62: recipe for target 'suruiha_gazebo_plugins/CMakeFiles/iris_controller.dir/src/iris_controller.cpp.o' failed
make[2]: *** [suruiha_gazebo_plugins/CMakeFiles/iris_controller.dir/src/iris_controller.cpp.o] Error 1
CMakeFiles/Makefile2:1606: recipe for target 'suruiha_gazebo_plugins/CMakeFiles/iris_controller.dir/all' failed
make[1]: *** [suruiha_gazebo_plugins/CMakeFiles/iris_controller.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/build.make:62: recipe for target 'suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/zephyr_controller.cpp.o' failed
make[2]: *** [suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/src/zephyr_controller.cpp.o] Error 1
CMakeFiles/Makefile2:481: recipe for target 'suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/all' failed
make[1]: *** [suruiha_gazebo_plugins/CMakeFiles/zephyr_controller.dir/all] Error 2
Makefile:138: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j4 -l4" failed
How can i solve this?
I know that the code is working, i saw it in the video of the person who shares it.
So something missing in my computer or i am doing something wrong.
Thanks…
