As a notice to all users of ur_msgs
(which would include Universal_Robots_ROS_Driver
users and potentially custom scripts using .srv
and .msg
definitions from ur_msgs
With the merge of ros-industrial/ur_msgs#8 the incorrect definition of the VOLTAGE
and CURRENT
domains in the Analog
message were fixed (they were switched wrt the documentation).
For comparison:
- the old definition
- the fixed definition
If you were using the VOLTAGE
and/or CURRENT
constant(s) in your scripts or nodes, please be aware that the values have changed, and verify your logic is now still correct.
NOTE: Universal_Robots_ROS_Driver
used the values reported by the UR controller directly, so it always reported correct values.
Only direct users of these constants (fi other drivers or custom scripts) will be affected.
