Hello everyone,
I’d like to share and release an easy to use repository I’ve created to help streamline and simplify the setup process for different ROS environments and it’s dependencies using Docker. The template provides a flexible and easy-to-use framework that allows you to configure the environment tailored to your specific needs.
I have been working on setting environments and packages that range across different OS and Distro requirements and managing them with Docker was definitely the shot. In this process I managed to shape this template for easily setting up different ROS envs with minimal efforts in listing and installing dependencies. My goal with this Docker template was to speed up the setup process, make it smoother, and eliminate the repetitive steps needed to get everything running.
Key Features:
- Pre-configured ROS env: The template comes with an initial ROS Noetic base version, making it quick to start developing without many additional setup steps.
- Configurable
.env
file: Easily modify arguments in the.env
andDockerfile
to fit your specific ROS version, dependencies, and configurations. - Customization: Easily modify the template to add any extra dependencies or changes as needed.
How it works:
- Simply clone the repository, customize the files mentioned in the
README.md
for your environment, and build your Docker image. - The template can be used for both ROS 1 and ROS 2 setups, and it integrates seamlessly with your ROS packages and dependencies.
There is scope for more work here and I’d love to get feedback from the community on how this template can be improved to make this as useful as possible for everyone. So if you have any suggestions, improvements, or features you’d like to see, please feel free to share! With this as a starter, I look forward to contributing more!!
You can find the repository here: GitHub - dipshikha-das/docker-env-blueprints at ros-any
Looking forward to your feedback!
