Milestone 11 will introduce support for OpenEmbedded release series newer than thud and migrate webOS OSE to version 2.x. This means that meta-ros
will be able to be built for Raspberry Pi 4. In order to reduce the number of combinations of OpenEmbedded release series and MACHINE
-s for which we do builds, we intend to replace building for raspberrypi3
with building for raspberrypi4
. However, we won’t do anything that knowing prevents others from building for Raspberry Pi 3.
If this change will cause you hardship, please respond on this meta-ros
GitHub issue by the end of 2020-01-17.
