We’re happy to announce 95 updated packages for ROS Indigo. Full details are below.
Thank you to all the maintainers and contributors who help make these packages available to the community!
Package Updates for indigo
Added Packages [0]:
Updated Packages [95]:
- ros-indigo-checkerboard-detector: 1.2.4-0 -> 1.2.6-0
- ros-indigo-dbw-mkz: 1.0.13-0 -> 1.0.17-0
- ros-indigo-dbw-mkz-can: 1.0.13-0 -> 1.0.17-0
- ros-indigo-dbw-mkz-description: 1.0.13-0 -> 1.0.17-0
- ros-indigo-dbw-mkz-joystick-demo: 1.0.13-0 -> 1.0.17-0
- ros-indigo-dbw-mkz-msgs: 1.0.13-0 -> 1.0.17-0
- ros-indigo-dbw-mkz-twist-controller: 1.0.13-0 -> 1.0.17-0
- ros-indigo-dynamic-tf-publisher: 2.2.7-0 -> 2.2.10-0
- ros-indigo-geometry-experimental: 0.5.18-0 -> 0.5.19-0
- ros-indigo-geometry2: 0.5.18-0 -> 0.5.19-0
- ros-indigo-image-view2: 2.2.7-0 -> 2.2.10-0
- ros-indigo-imagesift: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-common: 2.2.7-0 -> 2.2.10-0
- ros-indigo-jsk-data: 2.2.7-0 -> 2.2.10-0
- ros-indigo-jsk-interactive: 2.1.3-0 -> 2.1.4-0
- ros-indigo-jsk-interactive-marker: 2.1.3-0 -> 2.1.4-0
- ros-indigo-jsk-interactive-test: 2.1.3-0 -> 2.1.4-0
- ros-indigo-jsk-network-tools: 2.2.7-0 -> 2.2.10-0
- ros-indigo-jsk-pcl-ros: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-pcl-ros-utils: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-perception: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-recognition: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-recognition-msgs: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-recognition-utils: 1.2.4-0 -> 1.2.6-0
- ros-indigo-jsk-rqt-plugins: 2.1.3-0 -> 2.1.4-0
- ros-indigo-jsk-rviz-plugins: 2.1.3-0 -> 2.1.4-0
- ros-indigo-jsk-tilt-laser: 2.2.7-0 -> 2.2.10-0
- ros-indigo-jsk-tools: 2.2.7-0 -> 2.2.10-0
- ros-indigo-jsk-topic-tools: 2.2.7-0 -> 2.2.10-0
- ros-indigo-jsk-visualization: 2.1.3-0 -> 2.1.4-0
- ros-indigo-marti-data-structures: 2.5.0-0 -> 2.6.0-0
- ros-indigo-moveit: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-commander: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-controller-manager-example: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-core: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-fake-controller-manager: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-full: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-full-pr2: 0.7.13-0 -> 0.7.15-0
- ros-indigo-moveit-kinematics: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-planners: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-planners-ompl: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-plugins: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-pr2: 0.6.6-0 -> 0.7.15-0
- ros-indigo-moveit-ros: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-benchmarks: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-benchmarks-gui: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-control-interface: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-manipulation: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-move-group: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-perception: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-planning: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-planning-interface: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-robot-interaction: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-visualization: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-ros-warehouse: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-runtime: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-setup-assistant: 0.7.13-0 -> 0.7.14-1
- ros-indigo-moveit-simple-controller-manager: 0.7.13-0 -> 0.7.14-1
- ros-indigo-multi-map-server: 2.2.7-0 -> 2.2.10-0
- ros-indigo-pr2-moveit-config: 0.6.6-0 -> 0.7.15-0
- ros-indigo-pr2-moveit-plugins: 0.6.6-0 -> 0.7.15-0
- ros-indigo-rail-face-detection: 1.0.1-0 -> 1.0.2-0
- ros-indigo-rail-face-detection-msgs: 1.0.1-0 -> 1.0.2-0
- ros-indigo-rail-face-detector: 1.0.1-0 -> 1.0.2-0
- ros-indigo-rail-object-detection: 3.0.1-0 -> 3.0.2-0
- ros-indigo-rail-object-detection-msgs: 3.0.1-0 -> 3.0.2-0
- ros-indigo-rail-object-detector: 3.0.1-0 -> 3.0.2-0
- ros-indigo-resized-image-transport: 1.2.4-0 -> 1.2.6-0
- ros-indigo-swri-console-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-dbw-interface: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-geometry-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-image-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-math-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-nodelet: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-opencv-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-prefix-tools: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-roscpp: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-rospy: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-route-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-serial-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-string-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-system-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-transform-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-swri-yaml-util: 2.5.0-0 -> 2.6.0-0
- ros-indigo-tf2: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-bullet: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-eigen: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-geometry-msgs: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-kdl: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-msgs: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-py: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-ros: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-sensor-msgs: 0.5.18-0 -> 0.5.19-0
- ros-indigo-tf2-tools: 0.5.18-0 -> 0.5.19-0
- ros-indigo-virtual-force-publisher: 2.2.7-0 -> 2.2.10-0
Removed Packages [0]:
- Dave Coleman
- Ioan Sucan
- Isaac I. Y. Saito
- Jon Binney
- Kei Okada
- Kevin Hallenbeck
- Koji Terada
- Kris Kozak
- Marc Alban
- Mathias Lüdtke
- Michael Ferguson
- Michael Görner
- Micho Radovnikovich
- MoveIt Setup Assistant
- P. J. Reed
- Ryohei Ueda
- Siddhartha Banerjee
- Tully Foote
- Vincent Rabaud
- Yohei Kakiuchi
- YoheiKakiuchi
- Youhei Kakiuchi
- Yusuke Furuta
- furuta
