This sync brings 65 new packages to Kilted and updates 230 others. Thanks very much to the many developers that were a part of this effort, including the 58 maintainers listed below.
ros/rosdistro tag: kilted/2025-06-16
Added Packages [65]:
- ros-kilted-costmap-queue: 1.4.0-1
- ros-kilted-dwb-core: 1.4.0-1
- ros-kilted-dwb-critics: 1.4.0-1
- ros-kilted-dwb-msgs: 1.4.0-1
- ros-kilted-dwb-plugins: 1.4.0-1
- ros-kilted-foxglove-bridge: 0.8.5-1
- ros-kilted-nav-2d-msgs: 1.4.0-1
- ros-kilted-nav-2d-utils: 1.4.0-1
- ros-kilted-nav2-amcl: 1.4.0-1
- ros-kilted-nav2-behavior-tree: 1.4.0-1
- ros-kilted-nav2-behaviors: 1.4.0-1
- ros-kilted-nav2-bringup: 1.4.0-1
- ros-kilted-nav2-bt-navigator: 1.4.0-1
- ros-kilted-nav2-collision-monitor: 1.4.0-1
- ros-kilted-nav2-common: 1.4.0-1
- ros-kilted-nav2-constrained-smoother: 1.4.0-1
- ros-kilted-nav2-controller: 1.4.0-1
- ros-kilted-nav2-core: 1.4.0-1
- ros-kilted-nav2-costmap-2d: 1.4.0-1
- ros-kilted-nav2-dwb-controller: 1.4.0-1
- ros-kilted-nav2-graceful-controller: 1.4.0-1
- ros-kilted-nav2-lifecycle-manager: 1.4.0-1
- ros-kilted-nav2-loopback-sim: 1.4.0-1
- ros-kilted-nav2-map-server: 1.4.0-1
- ros-kilted-nav2-mppi-controller: 1.4.0-1
- ros-kilted-nav2-msgs: 1.4.0-1
- ros-kilted-nav2-navfn-planner: 1.4.0-1
- ros-kilted-nav2-planner: 1.4.0-1
- ros-kilted-nav2-regulated-pure-pursuit-controller: 1.4.0-1
- ros-kilted-nav2-rotation-shim-controller: 1.4.0-1
- ros-kilted-nav2-route: 1.4.0-1
- ros-kilted-nav2-rviz-plugins: 1.4.0-1
- ros-kilted-nav2-simple-commander: 1.4.0-1
- ros-kilted-nav2-smac-planner: 1.4.0-1
- ros-kilted-nav2-smoother: 1.4.0-1
- ros-kilted-nav2-system-tests: 1.4.0-1
- ros-kilted-nav2-theta-star-planner: 1.4.0-1
- ros-kilted-nav2-util: 1.4.0-1
- ros-kilted-nav2-velocity-smoother: 1.4.0-1
- ros-kilted-nav2-voxel-grid: 1.4.0-1
- ros-kilted-nav2-waypoint-follower: 1.4.0-1
- ros-kilted-navigation2: 1.4.0-1
- ros-kilted-nonpersistent-voxel-layer: 2.6.0-1
- ros-kilted-novatel-gps-driver: 4.2.0-5
- ros-kilted-opennav-docking: 1.4.0-1
- ros-kilted-opennav-docking-bt: 1.4.0-1
- ros-kilted-opennav-docking-core: 1.4.0-1
- ros-kilted-popf: 0.0.18-1
- ros-kilted-rclpy-cascade-lifecycle: 2.0.2-1
- ros-kilted-rmw-gurumdds-cpp: 6.0.1-1
- ros-kilted-rtabmap-conversions: 0.22.0-2
- ros-kilted-rtabmap-demos: 0.22.0-2
- ros-kilted-rtabmap-examples: 0.22.0-2
- ros-kilted-rtabmap-launch: 0.22.0-2
- ros-kilted-rtabmap-msgs: 0.22.0-2
- ros-kilted-rtabmap-odom: 0.22.0-2
- ros-kilted-rtabmap-python: 0.22.0-2
- ros-kilted-rtabmap-ros: 0.22.0-2
- ros-kilted-rtabmap-rviz-plugins: 0.22.0-2
- ros-kilted-rtabmap-slam: 0.22.0-2
- ros-kilted-rtabmap-sync: 0.22.0-2
- ros-kilted-rtabmap-util: 0.22.0-2
- ros-kilted-rtabmap-viz: 0.22.0-2
- ros-kilted-sick-safetyscanners2: 1.0.4-2
- ros-kilted-slam-toolbox: 2.9.0-2
Updated Packages [230]:
- ros-kilted-ackermann-steering-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-admittance-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-apriltag-detector: 3.0.1-3 → 3.0.2-1
- ros-kilted-apriltag-detector-mit: 3.0.1-3 → 3.0.2-1
- ros-kilted-apriltag-detector-umich: 3.0.1-3 → 3.0.2-1
- ros-kilted-apriltag-draw: 3.0.1-3 → 3.0.2-1
- ros-kilted-apriltag-tools: 3.0.1-3 → 3.0.2-1
- ros-kilted-aruco-opencv: 6.0.1-2 → 6.0.2-1
- ros-kilted-aruco-opencv-msgs: 6.0.1-2 → 6.0.2-1
- ros-kilted-battery-state-broadcaster: 1.0.1-2 → 1.0.2-1
- ros-kilted-battery-state-rviz-overlay: 1.0.1-2 → 1.0.2-1
- ros-kilted-bicycle-steering-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-cartographer: 2.0.9003-2 → 2.0.9004-1
- ros-kilted-cascade-lifecycle-msgs: 2.0.0-2 → 2.0.2-1
- ros-kilted-control-msgs: 6.1.0-1 → 6.3.0-1
- ros-kilted-control-toolbox: 5.3.1-1 → 5.4.0-1
- ros-kilted-controller-interface: 4.28.1-2 → 5.2.0-1
- ros-kilted-controller-manager: 4.28.1-2 → 5.2.0-1
- ros-kilted-controller-manager-msgs: 4.28.1-2 → 5.2.0-1
- ros-kilted-data-tamer-cpp: 1.0.2-1 → 1.0.3-1
- ros-kilted-data-tamer-msgs: 1.0.2-1 → 1.0.3-1
- ros-kilted-diagnostic-aggregator: 4.3.4-1 → 4.3.6-1
- ros-kilted-diagnostic-common-diagnostics: 4.3.4-1 → 4.3.6-1
- ros-kilted-diagnostic-remote-logging: 4.3.4-1 → 4.3.6-1
- ros-kilted-diagnostic-updater: 4.3.4-1 → 4.3.6-1
- ros-kilted-diagnostics: 4.3.4-1 → 4.3.6-1
- ros-kilted-diff-drive-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-dual-arm-panda-moveit-config: 3.1.0-2 → 3.1.1-1
- ros-kilted-effort-controllers: 5.0.0-1 → 5.1.0-1
- ros-kilted-event-camera-codecs: 1.0.5-2 → 2.0.0-1
- ros-kilted-event-camera-msgs: 1.0.6-2 → 2.0.0-1
- ros-kilted-event-camera-py: 2.0.0-2 → 2.0.1-1
- ros-kilted-event-camera-renderer: 1.0.4-2 → 2.0.0-1
- ros-kilted-ffmpeg-encoder-decoder: 2.0.0-2 → 2.0.1-1
- ros-kilted-ffmpeg-image-transport: 2.0.2-2 → 2.0.3-1
- ros-kilted-ffmpeg-image-transport-tools: 2.1.1-2 → 2.1.2-1
- ros-kilted-find-object-2d: 0.7.1-2 → 0.7.2-1
- ros-kilted-fkie-message-filters: 3.2.0-1 → 3.2.1-1
- ros-kilted-flex-sync: 2.0.0-2 → 2.0.1-1
- ros-kilted-flir-camera-description: 3.0.1-2 → 3.0.2-1
- ros-kilted-flir-camera-msgs: 3.0.1-2 → 3.0.2-1
- ros-kilted-force-torque-sensor-broadcaster: 5.0.0-1 → 5.1.0-1
- ros-kilted-forward-command-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-foxglove-compressed-video-transport: 1.0.2-2 → 1.0.3-1
- ros-kilted-geometric-shapes: 2.3.2-2 → 2.3.3-1
- ros-kilted-gpio-controllers: 5.0.0-1 → 5.1.0-1
- ros-kilted-gps-msgs: 2.0.5-2 → 2.1.0-1
- ros-kilted-gps-sensor-broadcaster: 5.0.0-1 → 5.1.0-1
- ros-kilted-gps-tools: 2.0.5-2 → 2.1.0-1
- ros-kilted-gps-umd: 2.0.5-2 → 2.1.0-1
- ros-kilted-gpsd-client: 2.0.5-2 → 2.1.0-1
- ros-kilted-gurumdds-cmake-module: 5.0.0-4 → 6.0.1-1
- ros-kilted-gz-ros2-control: 2.0.7-2 → 2.0.9-1
- ros-kilted-gz-ros2-control-demos: 2.0.7-2 → 2.0.9-1
- ros-kilted-hardware-interface: 4.28.1-2 → 5.2.0-1
- ros-kilted-hardware-interface-testing: 4.28.1-2 → 5.2.0-1
- ros-kilted-imu-pipeline: 0.5.1-2 → 0.6.1-1
- ros-kilted-imu-processors: 0.5.1-2 → 0.6.1-1
- ros-kilted-imu-sensor-broadcaster: 5.0.0-1 → 5.1.0-1
- ros-kilted-imu-transformer: 0.5.1-2 → 0.6.1-1
- ros-kilted-joint-limits: 4.28.1-2 → 5.2.0-1
- ros-kilted-joint-state-broadcaster: 5.0.0-1 → 5.1.0-1
- ros-kilted-joint-trajectory-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-kinematics-interface: 2.0.0-2 → 2.1.0-1
- ros-kilted-kinematics-interface-kdl: 2.0.0-2 → 2.1.0-1
- ros-kilted-kitti-metrics-eval: 1.7.0-1 → 1.9.0-1
- ros-kilted-laser-filters: 2.0.8-2 → 2.2.0-1
- ros-kilted-leo-bringup: 2.1.1-1 → 2.2.0-1
- ros-kilted-leo-filters: 2.1.1-1 → 2.2.0-1
- ros-kilted-leo-fw: 2.1.1-1 → 2.2.0-1
- ros-kilted-leo-robot: 2.1.1-1 → 2.2.0-1
- ros-kilted-libcaer-driver: 1.5.0-2 → 1.5.1-1
- ros-kilted-libcaer-vendor: 1.0.0-2 → 2.0.0-1
- ros-kilted-libmavconn: 2.10.0-1 → 2.10.1-1
- ros-kilted-libphidget22: 2.3.4-1 → 2.4.0-1
- ros-kilted-mapviz: 2.4.8-1 → 2.5.6-1
- ros-kilted-mapviz-interfaces: 2.4.8-1 → 2.5.6-1
- ros-kilted-mapviz-plugins: 2.4.8-1 → 2.5.6-1
- ros-kilted-mavlink: 2025.5.5-1 → 2025.6.6-1
- ros-kilted-mavros: 2.10.0-1 → 2.10.1-1
- ros-kilted-mavros-extras: 2.10.0-1 → 2.10.1-1
- ros-kilted-mavros-msgs: 2.10.0-1 → 2.10.1-1
- ros-kilted-mecanum-drive-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-message-filters: 7.1.0-2 → 7.1.1-1
- ros-kilted-microstrain-inertial-description: 4.6.0-2 → 4.7.0-1
- ros-kilted-microstrain-inertial-driver: 4.6.0-2 → 4.7.0-1
- ros-kilted-microstrain-inertial-examples: 4.6.0-2 → 4.7.0-1
- ros-kilted-microstrain-inertial-msgs: 4.6.0-2 → 4.7.0-1
- ros-kilted-microstrain-inertial-rqt: 4.6.0-2 → 4.7.0-1
- ros-kilted-mola: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-bridge-ros2: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-common: 0.4.0-2 → 0.4.1-1
- ros-kilted-mola-demos: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-gnss-to-markers: 0.1.0-2 → 0.1.1-1
- ros-kilted-mola-imu-preintegration: 1.8.0-2 → 1.9.0-1
- ros-kilted-mola-input-euroc-dataset: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-kitti-dataset: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-kitti360-dataset: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-mulran-dataset: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-paris-luco-dataset: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-rawlog: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-rosbag2: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-input-video: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-kernel: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-launcher: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-lidar-odometry: 0.7.2-1 → 0.8.0-1
- ros-kilted-mola-metric-maps: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-msgs: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-pose-list: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-relocalization: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-state-estimation: 1.8.0-2 → 1.9.0-1
- ros-kilted-mola-state-estimation-simple: 1.8.0-2 → 1.9.0-1
- ros-kilted-mola-state-estimation-smoother: 1.8.0-2 → 1.9.0-1
- ros-kilted-mola-traj-tools: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-viz: 1.7.0-1 → 1.9.0-1
- ros-kilted-mola-yaml: 1.7.0-1 → 1.9.0-1
- ros-kilted-moveit-resources: 3.1.0-2 → 3.1.1-1
- ros-kilted-moveit-resources-fanuc-description: 3.1.0-2 → 3.1.1-1
- ros-kilted-moveit-resources-fanuc-moveit-config: 3.1.0-2 → 3.1.1-1
- ros-kilted-moveit-resources-panda-description: 3.1.0-2 → 3.1.1-1
- ros-kilted-moveit-resources-panda-moveit-config: 3.1.0-2 → 3.1.1-1
- ros-kilted-moveit-resources-pr2-description: 3.1.0-2 → 3.1.1-1
- ros-kilted-mp2p-icp: 1.6.7-2 → 1.7.0-1
- ros-kilted-mrpt-apps: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libapps: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libbase: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libgui: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libhwdrivers: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libmaps: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libmath: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libnav: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libobs: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libopengl: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libposes: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libros-bridge: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libslam: 2.14.9-1 → 2.14.11-1
- ros-kilted-mrpt-libtclap: 2.14.9-1 → 2.14.11-1
- ros-kilted-multires-image: 2.4.8-1 → 2.5.6-1
- ros-kilted-mvsim: 0.13.2-2 → 0.13.3-1
- ros-kilted-nav2-minimal-tb3-sim: 1.1.0-3 → 1.2.0-1
- ros-kilted-nav2-minimal-tb4-description: 1.1.0-3 → 1.2.0-1
- ros-kilted-nav2-minimal-tb4-sim: 1.1.0-3 → 1.2.0-1
- ros-kilted-ntrip-client-node: 0.5.5-5 → 0.5.7-1
- ros-kilted-parallel-gripper-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-pcl-conversions: 2.7.1-1 → 2.7.3-1
- ros-kilted-pcl-ros: 2.7.1-1 → 2.7.3-1
- ros-kilted-perception-pcl: 2.7.1-1 → 2.7.3-1
- ros-kilted-phidgets-accelerometer: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-analog-inputs: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-analog-outputs: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-api: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-digital-inputs: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-digital-outputs: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-drivers: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-gyroscope: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-high-speed-encoder: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-ik: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-magnetometer: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-motors: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-msgs: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-spatial: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-stepper: 2.3.4-1 → 2.4.0-1
- ros-kilted-phidgets-temperature: 2.3.4-1 → 2.4.0-1
- ros-kilted-pid-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-pose-broadcaster: 5.0.0-1 → 5.1.0-1
- ros-kilted-pose-cov-ops: 0.3.13-2 → 0.3.14-1
- ros-kilted-position-controllers: 5.0.0-1 → 5.1.0-1
- ros-kilted-py-binding-tools: 2.0.1-2 → 2.0.2-1
- ros-kilted-random-numbers: 2.0.1-5 → 2.0.4-1
- ros-kilted-range-sensor-broadcaster: 5.0.0-1 → 5.1.0-1
- ros-kilted-rclcpp-cascade-lifecycle: 2.0.0-2 → 2.0.2-1
- ros-kilted-realtime-tools: 4.2.0-2 → 4.3.0-1
- ros-kilted-rmw-desert: 3.0.0-3 → 3.0.1-1
- ros-kilted-robot-localization: 3.9.2-3 → 3.9.3-1
- ros-kilted-ros-gz: 2.1.7-1 → 2.1.8-1
- ros-kilted-ros-gz-bridge: 2.1.7-1 → 2.1.8-1
- ros-kilted-ros-gz-image: 2.1.7-1 → 2.1.8-1
- ros-kilted-ros-gz-interfaces: 2.1.7-1 → 2.1.8-1
- ros-kilted-ros-gz-sim: 2.1.7-1 → 2.1.8-1
- ros-kilted-ros-gz-sim-demos: 2.1.7-1 → 2.1.8-1
- ros-kilted-ros2-control: 4.28.1-2 → 5.2.0-1
- ros-kilted-ros2-control-cmake: 0.1.1-2 → 0.2.1-1
- ros-kilted-ros2-control-test-assets: 4.28.1-2 → 5.2.0-1
- ros-kilted-ros2-controllers: 5.0.0-1 → 5.1.0-1
- ros-kilted-ros2-controllers-test-nodes: 5.0.0-1 → 5.1.0-1
- ros-kilted-ros2controlcli: 4.28.1-2 → 5.2.0-1
- ros-kilted-rqt-controller-manager: 4.28.1-2 → 5.2.0-1
- ros-kilted-rqt-joint-trajectory-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-rtabmap: 0.21.6-2 → 0.22.0-1
- ros-kilted-rviz-2d-overlay-msgs: 1.3.0-3 → 1.3.1-1
- ros-kilted-rviz-2d-overlay-plugins: 1.3.0-3 → 1.3.1-1
- ros-kilted-self-test: 4.3.4-1 → 4.3.6-1
- ros-kilted-septentrio-gnss-driver: 1.4.3-1 → 1.4.4-1
- ros-kilted-spinnaker-camera-driver: 3.0.1-2 → 3.0.2-1
- ros-kilted-spinnaker-synchronized-camera-driver: 3.0.1-2 → 3.0.2-1
- ros-kilted-srdfdom: 2.0.7-2 → 2.0.8-1
- ros-kilted-steering-controllers-library: 5.0.0-1 → 5.1.0-1
- ros-kilted-swri-cli-tools: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-console: 2.0.6-4 → 2.1.0-1
- ros-kilted-swri-console-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-dbw-interface: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-geometry-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-image-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-math-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-opencv-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-roscpp: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-route-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-serial-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-swri-transform-util: 3.7.5-1 → 3.8.4-1
- ros-kilted-test-ros-gz-bridge: 2.1.7-1 → 2.1.8-1
- ros-kilted-tile-map: 2.4.8-1 → 2.5.6-1
- ros-kilted-transmission-interface: 4.28.1-2 → 5.2.0-1
- ros-kilted-tricycle-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-tricycle-steering-controller: 5.0.0-1 → 5.1.0-1
- ros-kilted-ublox-dgnss: 0.5.5-5 → 0.5.7-1
- ros-kilted-ublox-dgnss-node: 0.5.5-5 → 0.5.7-1
- ros-kilted-ublox-nav-sat-fix-hp-node: 0.5.5-5 → 0.5.7-1
- ros-kilted-ublox-ubx-interfaces: 0.5.5-5 → 0.5.7-1
- ros-kilted-ublox-ubx-msgs: 0.5.5-5 → 0.5.7-1
- ros-kilted-ur: 4.0.0-1 → 4.0.2-1
- ros-kilted-ur-calibration: 4.0.0-1 → 4.0.2-1
- ros-kilted-ur-controllers: 4.0.0-1 → 4.0.2-1
- ros-kilted-ur-dashboard-msgs: 4.0.0-1 → 4.0.2-1
- ros-kilted-ur-moveit-config: 4.0.0-1 → 4.0.2-1
- ros-kilted-ur-robot-driver: 4.0.0-1 → 4.0.2-1
- ros-kilted-ur-simulation-gz: 2.2.0-2 → 2.3.0-1
- ros-kilted-urg-node: 1.1.1-4 → 1.2.0-1
- ros-kilted-velocity-controllers: 5.0.0-1 → 5.1.0-1
- ros-kilted-vision-msgs: 4.1.1-3 → 4.2.0-1
- ros-kilted-vision-msgs-rviz-plugins: 4.1.1-3 → 4.2.0-1
- ros-kilted-web-video-server: 2.0.0-2 → 2.1.0-1
Removed Packages [1]:
- Adam Allevato
- Aditya Pande
- Alberto Tudela
- Alejandro Hernández
- Alexey Merzlyakov
- Anas M’chichou
- Austin Hendrix
- Bence Magyar
- Bernd Pfrommer
- Brian Wilcox
- Błażej Sowa
- Carl Delsey
- Carlos Orduno
- Chris Lalancette
- Daan Wijffels
- Dave Coleman
- David V. Lu!!
- Davide Costa
- Davide Faconti
- Denis Štogl
- Donghyeon Lee
- Felix Exner
- Fictionlab
- Francisco Martin
- Francisco Martin Rico
- Geoff Sokoll
- Geoffrey Biggs
- Georg Novotny
- Hans-Joachim Krauch
- Jon Binney
- Jonas Otto
- José Luis Blanco-Claraco
- Juan Carlos Manzanares Serrano
- Lennart Puck
- Luis Camero
- Martin Günther
- Matej Vargovcik
- Mathieu Labbe
- Michael Ferguson
- Michael Jeronimo
- Mike Lautman
- Mohammad Haghighipanah
- MoveIt Release Team
- Nick Hortovanyi
- P. J. Reed
- Paul Bovbel
- Rob Fisher
- Robert Haschke
- Southwest Research Institute
- Steve Macenski
- Team Spatzenhirn
- Tibor Dome
- Timo Röhling
- Tom Moore
- Tyler Weaver
- Vladimir Ermakov
- fmrico
- steve
