We’re happy to announce 2 new packages and 35 updated packages. There’s one regression of a metapackage due to a new dependency that failed to build.
Thank you to all the contributors and maintainers who helped make these packages available!
Package Updates for kinetic
Added Packages [2]:
- ros-kinetic-phidgets-msgs: 0.7.10-1
- ros-kinetic-rr-openrover-simulation: 1.0.0-3
Updated Packages [35]:
- ros-kinetic-audio-capture: 0.3.5-1 -> 0.3.6-1
- ros-kinetic-audio-common: 0.3.5-1 -> 0.3.6-1
- ros-kinetic-audio-common-msgs: 0.3.5-1 -> 0.3.6-1
- ros-kinetic-audio-play: 0.3.5-1 -> 0.3.6-1
- ros-kinetic-cob-extern: 0.6.15-1 -> 0.6.17-1
- ros-kinetic-hebi-cpp-api: 3.2.0-1 -> 3.2.0-2
- ros-kinetic-ifm3d-core: 0.17.0-15 -> 0.18.0-2
- ros-kinetic-lgsvl-msgs: 0.0.2-1 -> 0.0.3-1
- ros-kinetic-libdlib: 0.6.15-1 -> 0.6.17-1
- ros-kinetic-libntcan: 0.6.15-1 -> 0.6.17-1
- ros-kinetic-libpcan: 0.6.15-1 -> 0.6.17-1
- ros-kinetic-libphidget21: 0.7.9-1 -> 0.7.10-1
- ros-kinetic-libphidgets: 0.6.15-1 -> 0.6.17-1
- ros-kinetic-mavlink: 2020.5.21-1 -> 2020.6.6-1
- ros-kinetic-mcl-3dl: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-opengm: 0.6.15-1 -> 0.6.17-1
- ros-kinetic-phidgets-api: 0.7.9-1 -> 0.7.10-1
- ros-kinetic-phidgets-drivers: 0.7.9-1 -> 0.7.10-1
- ros-kinetic-phidgets-high-speed-encoder: 0.7.9-1 -> 0.7.10-1
- ros-kinetic-phidgets-ik: 0.7.9-1 -> 0.7.10-1
- ros-kinetic-phidgets-imu: 0.7.9-1 -> 0.7.10-1
- ros-kinetic-pinocchio: 2.4.0-2 -> 2.4.5-1
- ros-kinetic-plotjuggler: 2.8.0-1 -> 2.8.1-2
- ros-kinetic-py-trees-ros: 0.5.20-1 -> 0.5.21-1
- ros-kinetic-rosapi: 0.11.8-1 -> 0.11.9-1
- ros-kinetic-rosbridge-library: 0.11.8-1 -> 0.11.9-1
- ros-kinetic-rosbridge-msgs: 0.11.8-1 -> 0.11.9-1
- ros-kinetic-rosbridge-server: 0.11.8-1 -> 0.11.9-1
- ros-kinetic-rosbridge-suite: 0.11.8-1 -> 0.11.9-1
- ros-kinetic-rr-control-input-manager: 0.8.0-1 -> 1.0.0-3
- ros-kinetic-rr-openrover-description: 0.8.0-1 -> 1.0.0-3
- ros-kinetic-rr-openrover-driver: 0.8.0-1 -> 1.0.0-3
- ros-kinetic-rr-openrover-driver-msgs: 0.8.0-1 -> 1.0.0-3
- ros-kinetic-sound-play: 0.3.5-1 -> 0.3.6-1
- ros-kinetic-urg-node: 0.1.13-1 -> 0.1.14-1
Removed Packages [1]:
- ros-kinetic-rr-openrover-stack
- Atsushi Watanabe
- Austin Hendrix
- Benjamin Maidel
- Chris Bollinger
- Daniel Stonier
- David Uhm
- Davide Faconti
- Florian Weisshardt
- Hans-Joachim Krauch
- Justin Carpentier
- Martin Günther
- Nicholas Padilla
- Nick Padilla
- Richard Bormann
- Russell Toris
- Sean Kelly
- Tony Baltovski
- Vladimir Ermakov
