Ouster_ros driver build fails under rolling
Any idea on why our build ouster package is failing?
https://build.ros2.org/job/Rdev__ouster-ros__ubuntu_jammy_amd64/1/console
I see the error points to unable to check out or find certain files:
12:07:35 [Clang-Tidy] Sleeping for 5 seconds due to JENKINS-32191...
12:07:35 [Clang-Tidy] Parsing console log (workspace: '/home/jenkins-agent/workspace/Rdev__ouster-ros__ubuntu_jammy_amd64')
12:07:40 [Clang-Tidy] -> found 10 issues (skipped 212 duplicates)
12:07:41 [Clang-Tidy] Parsing console log (workspace: '/home/jenkins-agent/workspace/Rdev__ouster-ros__ubuntu_jammy_amd64')
12:07:41 [Clang-Tidy] [-ERROR-] Can't create fingerprints for some files:
12:07:41 [Clang-Tidy] [-ERROR-] - '/tmp/ws/src/ouster-ros/ouster-ros/ouster-sdk/ouster_client/src/types.cpp', IO exception has been thrown: java.nio.file.NoSuchFileException: /tmp/ws/src/ouster-ros/ouster-ros/ouster-sdk/ouster_client/src/types.cpp
12:07:41 [Clang-Tidy] [-ERROR-] - '/tmp/ws/src/ouster-ros/ouster-ros/ouster-sdk/ouster_client/include/ouster/types.h', IO exception has been thrown: java.nio.file.NoSuchFileException: /tmp/ws/src/ouster-ros/ouster-ros/ouster-sdk/ouster_client/include/ouster/types.h
12:07:41 [Clang-Tidy] [-ERROR-] - '/tmp/ws/src/ouster-ros/ouster-ros/ouster-sdk/ouster_client/src/parsing.cpp', IO exception has been thrown: java.nio.file.NoSuchFileException: /tmp/ws/src/ouster-ros/ouster-ros/ouster-sdk/ouster_client/src/parsing.cpp
12:07:41 [Clang-Tidy] [-ERROR-] - '/tmp/ws/src/ouster-ros/ouster-ros/src/os_sensor_node.cpp', IO exception has been thrown: java.nio.file.NoSuchFileException: /tmp/ws/src/ouster-ros/ouster-ros/src/os_sensor_node.cpp
12:07:41 [Clang-Tidy] [-ERROR-] - '/tmp/ws/src/ouster-ros/ouster-ros/src/os_image_node.cpp', IO exception has been thrown: java.nio.file.NoSuchFileException: /tmp/ws/src/ouster-ros/ouster-ros/src/os_image_node.cpp
12:07:41 [Clang-Tidy] Post processing issues on 'agent-d588cefa' with source code encoding 'UTF-8'
12:07:41 [Clang-Tidy] Creating SCM blamer to obtain author and commit information for affected files
12:07:41 [Clang-Tidy] Skipping issues blame since Git has been configured with shallow clone
12:07:41 [Clang-Tidy] -> Git blamer could not be created for SCM 'hudson.plugins.git.GitSCM@2d75464d' in working tree '/home/jenkins-agent/workspace/Rdev__ouster-ros__ubuntu_jammy_amd64'
But I have cloned the repo into an empty ros2 workspace specifying the rolling-devel and the driver built successfully.
