Task rejected by legacy AcceptTaskRequest callback (#354)
Posted by @TheConstructAi:
[rmf_task_dispatcher-13] [WARN] [1684473786.013756728] [rmf_dispatcher_node]: Dispatcher Bidding Result: task [delivery.dispatch-1] has no submissions during bidding. Dispatching failed, and the task will not be performed.
[rmf_task_dispatcher-13] [ERROR] [1684473786.013822443] [rmf_dispatcher_node]: No submission error[1]: Task rejected by legacy AcceptTaskRequest callback
[rmf_task_dispatcher-13] [ERROR] [1684473786.013836414] [rmf_dispatcher_node]: No submission error[2]: Task rejected by legacy AcceptTaskRequest callback
This error appears when asking for a simple delivery through the web interface.
The robots are using the basic Fleet Adapter template adapted for them, and they navigate perfectly using Loop Tasks.
Its in the delivery that fails like this.
Any idea?
My setup is:
Ubuntu 22, ROS2 Humble, RMF installed form source the main branch.
Chosen answer
Answer chosen by @Yadunund at 2023-05-19T06:12:51Z.
Answered by @Yadunund:
It’s hard to answer your questions without looking at the implementation of your fleet adapter.
Have you enabled your fleet to perform delivery tasks?
fleet_adapter_template/fleet_adapter_template/config.yaml at 1fe945a20fcd6424b71f1c8c20600e7e4324c77d · open-rmf/fleet_adapter_template · GitHub
If you have enabled delivery, can you share the json description of the task you’re submitting? Does it work when requesting a delivery using a script from rmf_demos_tasks?
Posted by @Yadunund:
This is the chosen answer.
Solved, it wa sjust that…Not enableing it! Sorry for the dumb questin, the error just got e thinking it was something more serious :wink:
No worries. That printout is not too clear and we should improve it.
