Turtlebot Installation error
installed Ubuntu 14.04 on Virtual box machine.
then installed ROS INDIGO.
after that I tried to install turtlebot from the ROS Wiki.
but it gives an error in installation.
dpkg: error processing package ros-indigo-turtlebot-simulator (–configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
ros-indigo-librealsense
ros-indigo-realsense-camera
ros-indigo-turtlebot-bringup
ros-indigo-turtlebot-teleop
ros-indigo-turtlebot-actions
ros-indigo-turtlebot-calibration
ros-indigo-turtlebot-follower
ros-indigo-turtlebot-navigation
ros-indigo-turtlebot-rapps
ros-indigo-turtlebot-apps
ros-indigo-turtlebot-gazebo
ros-indigo-turtlebot-interactive-markers
ros-indigo-turtlebot-rviz-launchers
ros-indigo-turtlebot-interactions
ros-indigo-turtlebot-stage
ros-indigo-turtlebot-stdr
E: Sub-process /usr/bin/dpkg returned an error code (1)
pls help me to sort out this problem.
thank you
Regards
Samnan
Did you find a solution to this? I am seeing the exact same error while trying to install turtlebot on an Ubuntu 14.04 machine with ros indigo on it.
