Using ROS 1 and ROS 2 side by side using https://github.com/ros2/ros1_bridge works perfectly as we have detailed in our ROSCon talk
- “support is limited to only the message/service types available at compile time of the bridge”
- “topics will only be bridged when matching publisher-subscriber pairs are active for a topic on either side of the bridge”
- “building the ROS 1 bridge can consume a tremendous amount of memory”
- “first building everything else as usual, then coming back to build the ROS 1 bridge”
CMAKE_PREFIX_PATH
must not contain paths from ROS 1 which would overlay ROS 2 packages" - “The bridge will be built with support for any message/service packages that are on your path and have an associated mapping between ROS 1 and ROS 2”
- " This can be done by adding explicit dependencies on the message/service packages to the
package.xml
of the bridge"
That’s a lot of hoops to jump through, wouldn’t call it “works perfectly”. Just saying.
