About the role:
Head of Robotics – A senior technologist and leader with expertise in software enabled Robotic (UAVs and AGVs/AMRs) Control and Orchestration.
Working closely with and under the guidance of the CTO you will play a key role in the continued evolution of our software platform on the technology roadmap as envisioned by the CTO and will be involved in further expanding the team to succesfully deliver the roadmap.
This is a senior role in our Tech team which will lead a team of talented robotic engineers working on game-changing tech to develop commercial grade, autonomous robotic swarm solutions for the Industry 4.0 and Smart City markets.
This is a hands on role for someone who likes to roll up the sleeves as needed (instead of delegating everytime) to develop solutions, troubleshoot and potentially code daily.
You will be the technical lead on multiple projects contributing to requirements analysis, solution design, leading and engaging with customers, project partners and suppliers at a technical level.
While promoting high standards of code with your team and championing test-driven development. You will mentor less experienced engineers, assessing and appraising their quality of work and set targets around this.
You will set the standard when it comes to teamwork and collaboration throughout the solution development process while ensuring that software meets real-world usage scenarios.
Requirements
Minimum 6 years of experience in the field of Robotics with a focus on software for AGVs, UAV’s and other Robotic devices
Solution Architecture and Design experience for AGV and/or Drone enabled solutions
Deep knowledge of ROS (preferably ROS 2), C++ and Python for development in a Linux environment
Excellent knowledge of localisation and positioning techniques and approaches e.g. SLAM
Useful to have – AI and Machine Learning Knowledge and Experience
Excellent handle, knowledge and experience of coding standards, algorithms and computational complexity, data structures and control engineering
Excellent stakeholder management skills and experience (internal and external stakeholders)
Excellent written and verbal communication skills
Strong multi-tasking, time management and organisational skills
Experience with creating and deploying Docker containers
Experience with distributed systems
Education Required
Bachelors, Master’s or PhD in computer science, engineering, robotics, mechatronics or equivalent.
Start Date: ASAP
Where: Brussels, Belgium and/or Barcelona, Spain
Remuneration:** €65,000 - €85,000 Gross Annual Salary Dependent upon experience, company stock and benefits.
Type: Full-Time, Permanent
How to apply
Please apply by sending your Cover Letter and CV to careers@unmanned.life.
IMPORTANT - When applying please clearly specify your nationality and if you believe you will need an authorization, visa or other paper work to live and work in the EU
About the role:
Full Stack Robotics Engineer – An experienced full stack software engineer and technologist with expertise in software enabled Robotic (UAVs and AGVs/AMRs) Control and Orchestration.
Working closely with and under the guidance of the CTO you will play a key role in the continued evolution of our software platform on the technology roadmap as envisioned by the CTO with the main focus on design and development of the next generation of our web-based user interface and integration with third party solutions.
This is a key role in our Tech team which will lead on the full stack delivery on one or both of our core products for Industry 4.0 and Smart City markets respectively, working alongside a team of talented robotic software engineers and developers.
This is a fantastic opportunity for a highly skilled developer to join a fast growing business at an early stage of its growth journey.
As a leader you will technically advise and guide the successful delivery of multiple projects contributing to requirements analysis, solution design, leading and engaging with customers, project partners and suppliers at a technical level as appropriate.
Requirements
Minimum 5 years of experience across, Front and Backend development as well as Databases, and DevOps. Ideally this would be in the field of Robotics with a focus on software for AGVs, Drones and other Robotic devices
Should have NodeJS and VueJS knowledge and skills
Front End – Varying knowledge and experience ideally across all of the following, with expertise in a couple:
- HTML, CSS, JavaScript, jQuery, Angular, and ReactJS
Back End – Varying knowledge and experience across all of the following, with expertise in a couple:
- C++, Python, Java, PHP, knowledge of ROS is a plus
Databases – Varying knowledge and experience ideally across all of the following, with expertise in a couple:
- MySQL, MongoDB, Oracle Database, and SQL Server
DevOps – Varying knowledge and experience ideally across all of the following, with expertise in a couple:
- CI/CD (Continuous integration and continuous delivery) and related tools such as GitLab and Jenkins
Excellent handle, knowledge and experience of coding standards, object-oriented programming, data structures and design patterns.
Strong Linux competency
Useful to have – AI and Machine Learning interest and knowledge.
Useful to have - Stakeholder management skills and experience (internal and external stakeholders)
Useful to have - Experience with Docker containers
Education Required
Start Date: ASAP
Remuneration: €55,000 - €70,000 Gross Annual dependent upon experience plus benefits.
How to apply
IMPORTANT - When applying please clearly specify your nationality and if you believe you will need an authorization, visa or other paper work to live and work in EU.
About Unmanned Life
Unmanned Life is a global multi-award winning deep tech start-up. Our core IP is the world’s first 5G and AI enabled software platform which can deploy and manage at scale, integrated swarms of different types of robotic devices (UAV, AGV etc.) of varied capabilities, working together autonomously to deliver commercial grade autonomous solutions for the Industry 4.0 and Smart Cities market sectors.
Our Mission is to become the Go-To Software Platform for Seamless Orchestration of Autonomous Robotics.
Unmanned Life enjoys strong relations with a number of major Fortune 500 partners and clients with opportunities in multiple geographies (Europe, USA & Middle East). We are a growing company with offices in London, Brussels and Barcelona.
About the team
Unmanned Life is a start up with a fast growing, highly talented team (punching well above our weight) of over 9+ nationalities, educated at the world’s top schools in their respective disciplines with experience in deep tech and emerging technologies such as 5G, Cloud Computing, AI, Robotics, Autonomy as well as Business Leadership, Management and Sales in some of the world’s leading companies. We are the 2018 winners of the UK National Technology Award (and numerous others). We have existing projects, pilots, and strategic partnerships with household technology, telco and logistics players and industry behemoths such as Deutsche Telekom, Walmart, BT, Verizon, Nokia, SEAT, Telefonica & City of Vienna to name a few.
Our diverse team is highly motivated and unites on our mission to become the go to software platform for the seamless orchestration of autonomous robotics. To find out more visit: https://unmanned.life/
