Hey folks, I was hoping to get some feedback from others on a new bit of code I’ve written:
The goal is to have clean and consistent startup & shutdown behavior for python nodes. The catch is that I want this to work when I am using bindings to C++ ROS code. Therefore, I need the C++ ros::initialize to be called, hence the little roscpp_initializer you see here.
Do you think using a context manager is a good idea here? Do you have something similar to this in your code base? Thoughts on when this might fail/be a bad idea?
Thanks!
